Ok I have a Samsung M101 i bought it a while back and it doesnt play cd-r/w but some people have had some luck with certain brands of cdr's and what not if you give me the exact model number of the cdr's that would be better. Or maybe theres some other with maybe a boot disc or some sort!! i wanna play vcd's thats the main reason i finnaly got one of these cd burners!!!
- Tank
Samsung is known for making DVD players that dont support CDR, which is the case with DVD511 and yours might be the same thing (it is because the laser reader can decode only DVD standard or something very near to that). Good news is - there are certain CDR brands that will still play in Samsung DVDs even if the manual says it wont. Best one by far was PRINCO 24*, but they have ceased trading due to some royalty issues (you still might be able to get them from some suppliers with bigger stock reserve but it will be hard) so the only one left (that i know) at the moment is VIVASTAR 650MB CDR 32* - even suppliers put in the description for these CDRs that it is compatible with Samsung DVDs. Hope this helps.
http://www.vcdhelp.com/dvdplayers.php?DVDname=samsung+m101&DVDselect=&Search=Search
sorry...your out of luck...no cdr/cdrw support."Today is only yesterdays tomorrow"
Samsung HT-C450/XEU & Samsung BD-C5300 hacks/codes needed
By raindancerob in forum DVD & Blu-ray PlayersReplies: 8Last Post: 5th Mar 2011, 10:45 -
Samsung VR350. Can't play DVD anywhereelse but in Samsung VR350
By gux70 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 21st Aug 2010, 09:34 -
Samsung BD-P1590 VS Samsung BD-P1500?
By Darkerknight123 in forum DVD & Blu-ray PlayersReplies: 14Last Post: 3rd Jan 2010, 16:51 -
Samsung HT-Z210, Samsung HT-X250
By emmy207 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 28th Mar 2009, 22:06 -
Stand Alone Samsung HD Tuner vs. Samsung DVD Burner/Tuner
By MacPCConsultants in forum DVB / IPTVReplies: 0Last Post: 7th Jun 2008, 01:42
