I have been following leebears instructions for converting AVI to SVCD and am having some problems.
I completed the encoding using CCE and DVD2SVCD.
I am now at the steps using VCDEasy.
Question 1:
My first problem was, how do I know what the name of the MPEG2 file is created by DVD2SVCD (see cut below)? I think it is bbMPEG_Muxed_File.mpg
Question 2:
I started VCDEasy V1.1.2 and selected the above file (following the instructions from www.vcdeasy.org website). It hung for 6 hours with the please wait at the bottom at the bottom and the graph moving back and forth. Finally, I had to restore the task. My goal is to use Nero to burn the SVCD (like leebear in his instructions). Is there something wrong with VCDEasy or am I doing something wrong?
Thanks,
Rick
System: dell pentium 4, 750mHz, Win98SP2, DVD2SVCD 1.09b3, CCE2.5, VCDEasy 1.1.2 (I downloaded this today).
Here is the log from DVD2SVCD:
- 9/30/02 6:55:34 PM
- AVI to SVCD Conversion
- AVI2SVCD ver. 1.0.9 build 3
Initializing
Initializing finished.
- 9/30/02 6:55:35 PM
- Free on drive C: 9450.61 mb
- AUDIO Extraction
Audio extraction finished.
- 9/30/02 6:59:15 PM
- Free on drive C: 8856.52 mb
- AUDIO conversion
Converting Audio to MP2. Filename: C:\Program Files\DVD2SVCD\Rick\Extracted_audio_1.wav
Executing BeSweet. Commandline:
"C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "C:\Program Files\DVD2SVCD\Rick\Extracted_audio_1.wav" -output "C:\PROGRA~1\DVD2SVCD\RICK\Encoded_audio_1.mp2 " -logfile "C:\PROGRA~1\DVD2SVCD\RICK\Encoded_audio_1.log " ) -ota( -g max ) -2lame( -e -b 224 -m s )
Audio conversion of C:\Program Files\DVD2SVCD\Rick\Extracted_audio_1.wav finished.
Audio conversion finished.
- 9/30/02 7:08:40 PM
- Free on drive C: 9395.80 mb
- Video Encoding using Cinema Craft
Executing Cinema Craft Encoder.
StreamSectors: 771537788
AudioSectors: 75450984
VideoPAPO: 10782756
ScanOffsetBytes: 76292
SeqAligningBytes: 4848806
DVDBytes: 0
VideoEndHeader: 4
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 0.00
PureMPEGStream: 680378945.73
Seconds: 2658.69
CalcMPEGStream: 680378945.73
Frames: 63577
CDSize: 740.00
Cut point 736.00
Variable Settings:
Frames: 63577
Anti Noise Filter: Off
Passes: 4
Image Quality: 10
VAF file creation: On
Video Encoding Mode: Multipass VBR
Min. bitrate: 300
Max. bitrate: 2530
Avg. Bitrate: 2047
Aspect Ratio: 4:3 (No borders, encoded as 4:3)
---AVS Begin---
LoadPlugin("C:\PROGRA~1\DVD2SVCD\MPEG2DEC\MPEG2DEC .DLL")
AVISource("C:\MYMUSI~1\MONSTE~2.AVI")
ConvertToYUY2()
BicubicResize(480,464,.33,.33)
AddBorders(0,8,0,8)
ResampleAudio(44100)
----AVS End----
Closing program
CCE Max Speed: 0.630
Video Encoding finished.
- 10/1/02 12:57:47 AM
- Free on drive C: 8572.80 mb
- Video Pulldown
Executing Pulldown. Commandline:
"C:\Program Files\DVD2SVCD\pulldown\pulldown.exe" "C:\Program Files\DVD2SVCD\Encoded_Video_CCE_NTSC.mpv" "C:\Program Files\DVD2SVCD\Movie\Pulldown_Encoded_Video_NTSC.m pv"
Video pulldown finished.
- 10/1/02 1:04:55 AM
- Free on drive C: 8085.78 mb
- Converting Pictures from ES to PS
Saving bbMPEG settings: C:\Program Files\DVD2SVCD\bbMPEG\default.ini
- 10/1/02 1:04:57 AM
- Free on drive C: 8085.77 mb
- 10/1/02 1:04:59 AM
- Multiplexing and cutting
Offset in Seconds: 0
Executing bbMPEG.
Variable Settings:
Movie offset: 0 seconds
Cut point: 736 mb
Executing RunbbMPEG. Commandline:
"C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Program Files\DVD2SVCD\bbMPEG_Muxed_File.mpg"
Multiplexing and cutting finished.
CD-Image creation finished.
- 10/1/02 1:14:37 AM
- Free on drive C: 7347.38 mb
- SVCD Creation finished!
[/quote]
For those that like to hear me talk to myself
For some reason once I rebooted my PC, I was able to get VCDEasy to run and create the bin and cue files.
So, now I am off to search how to burn with Nero. I am making progress, slowly.
Here is the results from VCDEasy:
[Internal Xml Generation]
Internally computed XML generated successfully as "C:\Program Files\DVD2SVCD\Rick\videocd.xml"
[VCDxBuild.exe]
GNU VCDImager 0.7.12
initializing libvcd 0.7.12 [cygwin/i686]
this is the UNSTABLE development branch!
use only if you know what you are doing
see http://www.hvrlab.org/~hvr/vcdimager/ for more information
changed volume number to 1
changed volume count to 1
changed restriction number to 0
changing 'next volume use sequence 2' to 0
changing 'next volume use lid 2' to 0
changed volume label to `SUPER_VIDEOCD'
changed publisher id to `VCDEASY_V112'
changing 'relaxed aps' to 0
adding pbc (Selection-000/2)
adding pbc (Selection-end/3)
sequence count 1
adding sequence #0, C:\Program Files\DVD2SVCD\bbmpeg_muxed_file00.mpg
pts start offset 0.213367 (max pts = 2651.862367)
playing time 2651.649000
scanning mpeg sequence item #0 for scanpoints...
already scanned... not rescanning
pbc: psd size 56 (extended psd 0)
iso9660: highest alloced sector is 232 (using 300 as isosize)
OGT streams available: 0 0 0 0
writing track 1 (ISO9660)...
writing track 2, MPEG2, NTSC 2/3 D-1 (480x480/30fps), audio[0]: l2/44.1kHz/224kbps/stereo ...
MPEG packet statistics: 298944 video, 32380 audio, 0 zero, 0 ogt, 1 unknown
writting post-gap ('leadout pregap')...
finished ok, image created with 331925 sectors [73:45.50]
How to embed subtitles into mkv STEP BY STEP using MKVMERGE and MKVEXTRACT
By lelouch283 in forum SubtitleReplies: 30Last Post: 23rd Jun 2017, 14:04 -
MP4 X.264 to AVI XviD - Hard Sub with ssa subtitles (1 step or 2 step?)
By ssray23 in forum SubtitleReplies: 4Last Post: 29th Aug 2010, 19:35 -
Need DVD Rip Step-By-Step Instructions For Best Quality
By bht42 in forum DVD RippingReplies: 4Last Post: 26th Jul 2010, 09:28 -
The Complete Step By Step DVD Ripping/Burning Primer for Mac...?
By oliasdoug in forum MacReplies: 0Last Post: 10th Nov 2009, 07:04 -
Audacity guide for beginners, step-by-step
By AleksandrIgnatov in forum User guidesReplies: 3Last Post: 20th May 2007, 20:34
