Ive been trying to convert a xvid .avi file to SVCD using DVD2SVCD. I set everything up right, and the audio decodes and encodes fine, then when the video starts I get this error in the log:
Executing RunbbMPEG. Commandline:
"C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Program Files\DVD2SVCD\Movie\bbMPEG_Muxed_File.mpg"
bbMPEG failed. Exitcode: 3221225786
However, I get a popup error also that says something about the TMPGEnc NTSC.mpg file not found.. Then, when I try to open TMPGEnc again it wont run and I get that ugly sound. Even restarting the computer, I had to uninstall TMPGEnc and install another version just to get it to run.. Im on my 3rd version of TMPGEnc now, the other 2 wont run anymore, even after reinstalling.
I tried using CCE last time and it worked perfectly, changing nothing else but the encoder choice in DVD2SVCD.
Anyone know why TMPGEnc is screwed up now and why I cant even get it to run now, and why it didnt work in the first place? Thanks!
Results 1 to 1 of 1
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 16:08
