how do I convert 30fps AVI to Pal 25fps using TMPgenc.
I`ve tryed searching this forum but i haven`t managed to come up with anything. I know how to convert films that are 23.9 to 25 using Vitua Dub and BeSweet for the audio and using a Pal template in TMpenc, but I`m completetly stumped with 30fps. Tryed besweet for downconverting the audio from 29.7 to to 25 but the audio plays goes very slow. Any ideas also for converting 20fps to Pal 25.
people ignore double post.
Where I walk, I walk alone. Where I fight, I fight alone. -
You can take me for a fool
, but why to convert audio? Just demux, convert vid, remux and this should do I thing. Never did framerate conversions myself...
Just a thought, if you encode in TmpGenc at 25fps it should work, video may look a little jerky tho as TmpGenc will trow frames away to achieve this. I would try it on a test sample to see if the result is acceptable.
I might try that muxing thing then Epo. So what do you do in Steps. Do I need to pull the audio off in a wave using VDub or just strip it off using Tmpenc
Convert 24p .mov to interlaced 25fps PAL
By Cotswold in forum Video ConversionReplies: 6Last Post: 25th Mar 2012, 16:50 -
canon 5d mkII 30fps to 25fps best way to convert?
By powertase in forum Video ConversionReplies: 3Last Post: 20th Sep 2009, 22:53 -
30FPS PAL DVD to XVID Avi
By andy_blah in forum DVD RippingReplies: 13Last Post: 19th Jul 2008, 06:28 -
Converting 30fps Progressive to 25fps interlaced ? (Avisynth & VDub)
By blewyn in forum Video ConversionReplies: 6Last Post: 12th Jun 2008, 18:51 -
30FPS Progressive to PAL Interlaced? (DSC MJPEG AVI to DVD)
By ezekiel42 in forum Video ConversionReplies: 7Last Post: 8th Jul 2007, 23:53
