    May 2002
    the Netherlands
    Hi there...
    What is the most efficient way to convert dvd to vcd ?
    and with what program's to do it ?
    I have used Dvdx 2.0 but the output is poor, the subtitles are hard to read and the color of the subtitle is grey instead of white.
    So, does anyone know an easy and understandable solution ?
    Thanx
    Dennis
  2. Member Treebeard's Avatar
    Aug 2002
    http://www.vcdhelp.com/sefy/?id=ClassicalGuide.html
    good guide.
    i use smartripper, dvd2avi, tmpgenc, and nero to burn my discs.
    takes time and effort but results are worth it, especially when making SVCD's
  3. i have no probs with dvdx
  4. Member Treebeard's Avatar
    Aug 2002
    Just giving you an alternate way to try
  5. There are many many ways of doing it. I suggest that you have a look at the guides at http://www.doom9.org
    Regards.
    Michael Tam
    w: Morsels of Evidence
    Aug 2002
    Germany
    Try DVD2SVCD
    Jul 2001
    One Step From Hell
    I use Smartripper>dvd2avi>tmpg>bbmepeg>vcdeasy>cdrwin
    Using 2-pass I get close to dvd looking.
    I don't use one guide. I take alittle bit here and alittle bit there and combine um to get the best results.
  8. Originally Posted by SLBOSS926
    good guide.
    actually, it doesn't take that much time once you get used to it....
    using multiprograms rather than all-in-one proggies like dvd2svcd gives more flexibility....(i.e. you can choose to frameserve into tmpgenc through a whole lotta proggies like vdub and flask)
