IF the svcd has been made correctly , right click on the .mpg and choose " Open with ..." (for instance Wind. media player or PowerDvd) .
Results 31 to 48 of 48
bighousie,
I do that, and my computer locks or does not open this file (a file on the CD disk). Hence Nero 5590 made this SVCD not correctly, but why, what should I check?
nimco -
Thanks for your help am trying it now and hopefully it will work. I too have Nero with the plug in but it doesn't seem able to burn the file so I will keep trying your way.
Originally Posted by nimco
When it's finished encoding do I burn with VCD Easy the way I would burn a VCD?
Encoding seemed to go well but when I ran VCD Easy it scanned okay and started writing then stopped and said error writing data writing failed - buffer underun? Writing failed. What should I do?
???? I wished i knew! I should say try again after checking if all the settings are OK.
Originally Posted by barb210
does your drive support buffer underrun protection?
were you doing a lot of other stuff in the background while you were burning?
try this: mount your image with daemontools, and do a cd copy and/or try lowering your burn speed(w/or w/out using daemontools)what are you askin' me for...
I'm an idiot! -
Thanks, not sure about mounting an image and I don't have daemon tools but I will try lowering the write speed and do it when nothing else is on.
you can find daemontools in the tools section.
as far as mounting the image--piece of cake.
run daemontools.
click on the icon in the system tray
select the .cue filewhat are you askin' me for...
I'm an idiot! -
I think I must be the idiot. Have downloaded daemon tools and located the cue file, what do I burn it with?
How can I make a cd copy if I don't have the original, it is on the hard drive of the computer?
Okay managed to burn slightly with Nero, but it cut out after 25%. When I looked at the cd it played ok to start with but then split screens to show another movie that was on my hard drive that I had encoded at a different time and that wasn't to SVCD quality. What do you think I have done wrong?
I am having very similar problems trying to make an SVCD from a Premier timeline. Choosing the SVCD template in TMPGenc, OK. Is there anything else that needs to be set? SVCD is supposedly 480 x 480, so does that have to be set somewhere? What other settings are required if any? thanks
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 07:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 12:13 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 08:34 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
