I am trying to convert my 8mm tapes to view on my DVD player. I am relatively inexperienced in this arena. I purchased the Dazzle 80 and realized that was mistake one. They tried to get me to purchase the DVC 200, but after reading the comments on this site, I realize that could have been mistake two. If I understand correctly, there are three components (Capture, Edit, and Burn). What are the best devices to use to get the same quality on my DVD as if the CAMCorder was connected directly? I have Nero 5.5 (I think that could address the "Burn" piece. Any help is greatly appreciated.
What I use to do exactly what you are trying to do is the following.
1. I capture with a Canopus ADVC-1394 using Vegas Video 3.0 (works great, 2+hours of capture per tape and I might have 1-2 dropped frames if that)
2. Edit the footage with Vegas Video 3.0
3. Encode the footage with Vegas Video 3.0 (MainConcept) using their DVD template (About 5-7 hours for 2 hours of footage)
4. I use ULead DVD factory to burn the DVD. I don't usually bother with menus and stuff so all I use it for is to burn the DVD.
The results are exaxt duplicates of the 8mm tapes played in my camcorder. Couldn't be happier.
HTH
DVD for viewing on tv?
By frenchman96 in forum Video ConversionReplies: 1Last Post: 15th Jan 2010, 12:09 -
What is the best camcorder for 8mm to dvd.
By krlorenz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Dec 2007, 14:58 -
40yr old 8mm to dvd
By ACLUguy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 21st Dec 2007, 05:51 -
8mm film to DVD ????
By StuR in forum RestorationReplies: 31Last Post: 29th Nov 2007, 10:21 -
Top quality professional transfer of 8mm and Super 8mm film
By cosmichippo in forum Video ConversionReplies: 75Last Post: 25th Jul 2007, 22:28
