  1. hello everyone!
    i´m really new to this!
    my movie is two 850 mb mpg files....do i have to split these two files into four to get it to fit on cd´s?? i want to make them fit into two! but is this impossible?...if i have to split them how can i do it?
  2. Member Treebeard's Avatar
    Aug 2002
    you dont need to post multiple times! especially within a minute of each other
    Georgetown, TX
    From what I know (so far), it is not impossible. You'll just need to reencode your movie at either a lower constant bitrate alltogether, or encode it using a variable bitrate. It'll take some experimentation to see which one works best for you.
    -- Matt
