hello everyone!
i´m really new to this!
my movie is two850 mb mpg files....do i have to split these two files into four to get it to fit on cd´s?? i want to make them fit into two! but is this impossible?...if i have to split them how can i do it?
Closed Thread
dickemmanen,
You may not have to split things up. Depending on what your using to say you have an 850meg file, you might be OK with your 700mb/80min cdr. Some programs/utilities define a megabyte as 1048576 bytes (1024 x 1024), some as 1024000 (1024 x 1000) and some as 1000000 bytes (1000 x 1000). What you may have, if its a VCD standard and not much more than 80 mins, just enough to fit on one cdr.
What I usually do to check is load the mpg in Nero like I was going to burn and see what will actually fit within the 80mins. If its not going to fit, you have a few options.
1-If its not much more than 80 mins, say 81 to 82mins tops, and your burner and cdrs support overburning, then just overburn.
2-If no overburn...Using the MPEG Tools in TMPGenc, use MERGE/CUT to clip off the beginning or end (or just some bad scenes, like nudity
) of the mpgs and make it under the 80min mark. Things like opening and closing scenes and credits can do wonders for gaining size.
3-Perhaps a combination will do. Cut out a total of 10 minutes or between the two files, merge the two pieces together, re-cut to fit on 2 cdrs.
4-The good old merge, cut and burn to 3 cdrs as suggested earlier.
5-Get some 90min CDRs. 8)
Hope this helps,Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
Don't post the same question on several forums!
http://www.vcdhelp.com/forum/viewtopic.php?t=115713
Regards.Michael Tam
w: Morsels of Evidence
Please Help!-2:46:22 (690 MB) .WMV file will NOT fit on DVD which is 4.7G
By facepalm!! in forum Newbie / General discussionsReplies: 17Last Post: 6th Jan 2012, 03:52 -
how to fit a 7gb mpg to a 4.7 dvd?
By just in forum Newbie / General discussionsReplies: 4Last Post: 25th Oct 2008, 04:38 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
Unable to fit file to dvd?
By Ado in forum Video ConversionReplies: 5Last Post: 5th Aug 2007, 19:20 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
