hello everyone!
i´m really new to this!
my movie is two 850 mb mpg files....do i have to split these two files into four to get it to fit on cd´s?? i want to make them fit into two! but is this impossible?...if i have to split them how can i do it?![]()
you could split them and have 4 files
or you could merge them and re-cut them to 3 files
tmpgenc or virtualdub can do this - you cand find this on the left column under tools
merging and cutting will give you 1 less disc but can be more tricky.
its up to you -
If it is MPEG1 then you could probably get one onto a 800MB disc.
You can always try to overburn if you have a compatible drive (like Lite-On)
Or use 90 or 99 min CDRs
Try, try, tryPanasonic DMR-ES45VS, keep those discs a burnin' -
This is definitely the best way.Originally Posted by kitty
Regards.Michael Tam
w: Morsels of Evidence -
OR, you could run it through TMPGEnc to make XVCD with just a bit lower bitrates so that the output file is around 790 MB and then burn using Nero - that is IF your DVD player supports XVCD.
P.S. That way you could actually fit BOTH files on 1 CD but it is not recommended. -
Re-encoding an MPEG should be your last, last choice. Not only will it take a long time but you will seriously loose some quality.
Regards.Michael Tam
how to fit a 7gb mpg to a 4.7 dvd?
By just in forum Newbie / General discussionsReplies: 4Last Post: 25th Oct 2008, 05:38 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
auto fit
By roystheboy in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Jun 2008, 06:23 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47
