Firstly let me apologise if this problem is a dupe, i tried the search function and came up blank.
Basically i downloaded an mpeg from a website and when i played it, it played the 15mins or so of footage but in media player, power dvd, elcard mpeg2 player and global divx it all gave me a run time of just over 1 minute.
When i went to burn it with nero just to check compatability it picked up it was not a valid mpeg source, i checked the resolution and the bitrate - all vcd ntsc standard, but the audio was single channel 96kb - this didnt explain the length issue though.
I have had this problem before and fixed it (don't remember how).
I tried re-encoding with tmpeg but it only re-encodes the first minute, even using cut function in mpeg tools where i select the beginning and end of the movie, i tried re-writing the header with mpeg corrector but then just get a non-valid mpeg file.
Any help would be much appreciated.![]()
You can use VCDGear's MPeg to MPeg function to fix errors like the one your describing. Look in the TOOLS section to the left for it.
Impossible to see the future is. The Dark Side clouds everything... -
I already tried that before i resorted to posting, sorry should have mentioned that probably, it came out as 40mb file. Thanks for the response though
Should probably also mention therefore that i tried vcdeasy and it recognized it as an mpeg stream but the bin/cue file came out at like 20mb and it seemed to write the image before it even scanned the file. Again it only clocked the duration at just over a minute."Remember my friends... life is too short.. for negative energies.." Li Jun Fan (11/27/1940 - 7/20/1973 -
also just tried re-recording with ifilm edit and it wont even open it.. before anyone suggests that
VCD true compatability will want stereo 224kb/s
If you demux audio with TMPGenc you can change this in a sound editor & remux.Panasonic DMR-ES45VS, keep those discs a burnin' -
yep but thats part i plan to do once i sort the video problem
which is where the problem lies, it only recognizes 1min or so of video, im trying to solve the problem as we speak by frame-serving to tmpeg via virtual dub which recognized the file as its true length so far its working
Ok, the vdub worked, i simply opened it with vdub frame-served to tmpeg and re-encoded to mpeg1 again, then extracted the wav also with vdub, converted to 224kbps with bsweet and muxxed.
Just explaining because hopefully this will serve someone else with a similar problem rather than becoming a wasted thread.
Thanks to those who replied for your help though"Remember my friends... life is too short.. for negative energies.." Li Jun Fan (11/27/1940 - 7/20/1973 -
In worse case extremes like this, I use DVD2AVI to fix MPEG errors, serving the MPEG back to an avi. If you have the same problem with an MPEG-2, you can use this fix. It also works on MPEG-1.
Problems with mpeg-2 ts
By SINZAR in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2012, 16:39 -
Mpeg Problems
By marbletravis in forum EditingReplies: 4Last Post: 23rd Jun 2008, 12:24 -
MPEG-2 Problems...
By shorto in forum Newbie / General discussionsReplies: 3Last Post: 29th Dec 2007, 13:14 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
MPEG 2 problems
By specwarrior09 in forum Capturing and VCRReplies: 5Last Post: 26th Aug 2007, 12:16
