Hi there,
First of all, I'm new at this so please don't bite my head off if this is a dumb question. Here we go:
I'm planning on getting an Apex AD-1500 player since I use SVCD's alot. It's also cheap and I like the "File Browse" feature. The trouble is I live in Sweden (PAL/220VAC/REG2), and I can't find the player anywhere in europe. So most likely I'd need to order one from the states, wich means NTSC/110VAC/REG1.
Now, the AC is pretty easily solved, and possibly the region aswell if I can get a reghack. But what about the output format? Will the DVD player always output NTSC, or maybe NTSC with NTSC discs and PAL with PAL discs, or can I tell it how to output?
I'd really appriciate some pointers.
Later!
/Hamlet
Hello Hamlet,
I see Apex players all the time here in the US. I think it's fair to say you get what you pay for. I don't believe the format conversion is that good based on what I've read.
I have a Philips Q35 which has as it's closest cousin in Europe the Q40 I believe. This player supports both PAL and NTSC. I have the film Ronin in R1 and R2 and visually it is hard to tell the difference.
Many people have good things to say about Malata players when it comes to format conversion. Sampo and Daewood have many followers too.
For a bit more money, there is also Skyworth but it's hard to find.
Cheers,
Tony -
The Apex 1500 lets you select an NTSC, PAL or a MULTI TV. My understanding is that it will play on any of those TVs, PAL or NTSC DVDs (provided you have region hacked it with a region free firmware or a modchip).
See these websites for more info:
www.nerd-out.com
http://www.apexdigitalinc.com/images/products/manuals/AD-1500.pdf
DVD Player Converts PAL to NTSC
By wulf109 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2011, 18:56 -
Will a homemade NTSC dvd play on a PAL player?
By thedarkness in forum Newbie / General discussionsReplies: 9Last Post: 23rd Nov 2010, 03:54 -
DV recorder/ player for NTSC and Pal ???
By Dash1 in forum Capturing and VCRReplies: 3Last Post: 19th May 2008, 07:50 -
Cheap, reliable ntsc/pal dvd player?
By BIFFtheSTIFF in forum DVD & Blu-ray PlayersReplies: 1Last Post: 9th Feb 2008, 21:44 -
NTSC/PAL DVD player
By jonas more in forum DVD & Blu-ray PlayersReplies: 24Last Post: 9th Jan 2008, 07:40
