It's probably an obvious question, but can you continue to add more Video to a VCD cd after you have burnt it? (and having left the CD open)
All the files I'm burning are vcd compliant (so I'm not asking about that) and I have made a several VCDs (anime's) so I do know how to burn a CD once.
What's happening is that I've got some VCD's where I've got a remaining 50 or so minutes on, so I leave the CD open to write more. (unticking the box next to finalise CD). Is there a way to continue to use the VCD as a VCD (adding more video)? (I know I can add more data)
I'm using nero 5.5, and no menues or anything fancy.
No.
The most pertinent info on a VCD is in the PBC which is written in track one. It contains information about all the video tracks.
That is, you (the authoring/burning proggy) basically need to know the layout of the entire VCD before it starts burning.
It doesn't matter that you didn't "finalise" the disc. You can't add any extra video tracks to it (with the expectation that it will work).
Regards.Michael Tam
w: Morsels of Evidence -
instead of leaving the disc open drag several mpegs over in nero and use the menu option in nero. then when you play it in the standalone it will bring up the menu and you can pick which video to watch. then your not wasting disc space
thank you vitualis, that's exactly what I wanted to know (not exactly what I wanted to hear tho)
Adding controls to a swf (then adding to website)
By AshleyQuick in forum Newbie / General discussionsReplies: 6Last Post: 14th Oct 2011, 03:02 -
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 09:55 -
Help burning vcd
By Reds in forum Authoring (VCD/SVCD)Replies: 3Last Post: 8th Feb 2008, 07:20 -
vcd burning
By srckaimal in forum Newbie / General discussionsReplies: 26Last Post: 6th Dec 2007, 06:23 -
free software for adding voice through mic to vcd
By andreytenov in forum EditingReplies: 4Last Post: 12th Nov 2007, 03:20
