Hi-
i have been having a hard time getting vcd quality to be what I would like. i am just shooting for vhs quality. whenever i make a vcd, it becomes somewhat pixelated. I have editted my material in premier and exported it as an ms dv avi. is there something i can do to increase quality?
thanks
greg
first thing to remember, the output is directly related to your input. what format are you using to capture, AVI, MPEG2??
second VCD format has it's limitations the bit rate in comparison to dvd(mpeg2) is low. so vcd can only be so good
capture at the highest quailty your system and software can handle, then experiment with increasing bitrates to see what will play on your dvd player (use cd-rw)"The software said Win XP or better, so I Installed Linux"
901102 - best VCD quality
By hamidi2 in forum Video ConversionReplies: 32Last Post: 26th Aug 2018, 18:49 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
Movie quality for VCD
By dilanalex in forum Newbie / General discussionsReplies: 12Last Post: 21st Apr 2009, 01:42 -
How to add Watermark to VCD MPEG1 without Quality Loss?
By shebi in forum Authoring (VCD/SVCD)Replies: 3Last Post: 15th Apr 2009, 13:13 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 02:18
