I need the the original control byte/prom options for LG 5822P (region 4 if needed). Had the information for how to get a VCD to play on an LG 5822N, and one of my idiot mates has decided to 'custom' my player. its now stuck in black and white. Any help would be greatly appreciated as no doubt this has happened to others who have failed to write them down.
NOTE: if you do write them down put them in a safe place, mine were ripped up and eaten. (Since this i have been told by a few people are my friends really friends, some other stuff has happened too)
Thanks in advance
well, i cant help with the LG 5822P proms, but from what i can gather most of them are similar, so i can give you the defaults for the 5502p(region 4) ...you can always try them and see if it works.
here they are
41 55 00 ce 12 55 10 00
might not help, but theres no harm in trying right?I'm Not Really Here -
Thanks anyway greatanvil. Unfortunately that didn't fix the problem. Still must be wrong, found out he only touched 1,6,7 and possible eight. If anyone can else can help i would greatly be in debt to you. Thanks in advance
Or is there anyway to reset the player. eg comepetly make it forget anything done to it, like if some had the parental control. -
sorry i couldnt help. ive got sort of the same problem with mine, it only plays region 4 dvds in colour. any other region is in black and white.
I'm Not Really Here
Pavtube - Byte Co[py
By charlie_brownuk in forum Blu-ray RippingReplies: 6Last Post: 26th Sep 2011, 09:04 -
LG HT503 Prom Option Default (region settings)
By RedSquirrel1983 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 28th Jan 2011, 10:25 -
ffmpegX gives me 0 byte flash file
By flim in forum ffmpegX general discussionReplies: 2Last Post: 9th Apr 2010, 13:12 -
HELP! FAVC 1.04- Why is it creating 0 byte iso's at times?
By spexwood in forum Video ConversionReplies: 7Last Post: 5th Dec 2007, 23:40 -
Convert Media Exactly to allow joining by byte manipulation alone.
By benshole in forum EditingReplies: 0Last Post: 22nd Nov 2007, 06:51
