  1. Guest
    this isn't big news to most of us, but it is cool because he mentions this website, compares software, and more importantly-- i'm in it. hehe
    http://www.usnews.com/usnews/issue/021007/tech/7video.htm
    -heidi
  2. Member holistic's Avatar
    May 2001
    here & there
    Well done on your home movie conversions.
    Looks like you got your 15 minutes of fame..
    Did you make VCD's from those home tapes?
    If i may suggest : For a better quality digital copy - take the original *.avi and encode it in TMPGEnc at a high bitrate MPEG2. [ (3000-4500-6500) is what i sometimes use.]
    With this higher quality material you can later make DVD's when the prices drop. *** Be sure to use one of the DVD standards.
    regards ][
