TMPGenc has been working well for me on most avi's I convert, but for some reason on others it doesn't recongize any audio. For example, I downloaded Spy Kids, and when you click on the Select Source button and check the Display Audio checkbox, it doesn't show any audio. The audio works fine when you play it as an avi, but TMPGenc can't find it, and if you do convert to mpg using TMPGenc, then there is no audio. Why is this?
Ed B.
TMPG has problems with certain encodes of avi's...it fails somewhere during the uncompresion>conversion>recompression.
Most times you can get around it by using a program like Virtual dub and extracting the soundtrack as a uncompressed pcm wav file...take that file and use it as the audio source for the encode to mpg along with the original avi as the video source. -
TMPGEnc has its limitation, among which the fact that it does work well with certain types of audio, like AC3 and MP3 VBR for instance.
The solution in that case would be to use special versions of VirtualDub to extract the audio, convert it to PCM Wav using tools like Headac3he for instance, then use the resulting audio file as audio input for TMPGEnc.
This should bypass the problems you are having.
Cheers
AVI (with Ac3 audio) to DVD using TMPGenc 2.5 Plus
By CaptainChaos in forum Authoring (DVD)Replies: 7Last Post: 2nd Mar 2012, 08:03 -
Convert AVI to ? to TMPGEnc DVDAuthor with 5.1 audio
By NDMMackay in forum Video ConversionReplies: 2Last Post: 15th Oct 2011, 08:02 -
Cause of A/V sync and how recognize when a video has VFR and audio has VBR?
By Stb1990 in forum Newbie / General discussionsReplies: 3Last Post: 18th Apr 2010, 21:05 -
convertx wont recognize avi
By brdhsby5 in forum Video ConversionReplies: 4Last Post: 20th Aug 2008, 18:01 -
tmpgEnc 4.0 express didn't recognize mp4 & mkv
By pcb in forum Newbie / General discussionsReplies: 12Last Post: 10th Apr 2008, 03:36
