Does anyone know what the minimum system requirements (processor, memory, capture card) are to capture using the Huffy codec? My computer always hangs and I'd like to know if I need to upgrade my system.
If your computer hangs then it's an operating system error, not huffyuv.
You don't by chance have a VIA based MB? -
My system is only a Celeron 633 with 64 MB RAM at PC100 (8MB shared for video) and I'm trying to capture with a Studio VCD capture card using the Huffy codec. My video and sound are VIA.
cpu ok - but more memory may be a good idea ..
running any windows on 64meg is pretty ragged ..
try fastest / lossless setting (top right hand window) of huffyuv .. less cpu/system overhead (bigger file though) -
Thank you all for your advice -- I'll give the Huffy settings a try. I've actually tried adding more memory (64MB RAM - PC100) but my computer started working funny and hanging even more, especially VirtualDub.
your system is faster than mine,but i can cap with out dropping frames usually,i mainly use morgan mjpg codec it never dropes frames,and try another capture program like av-io or video wave,virtual dub drops frames alot when i use it but if i use a different capture program it works great.i can capture huffyuv also with out dropping frames,even 480 by 480.
Hi svet
>> I've actually tried adding more memory (64MB RAM - PC100) but my computer started working funny and hanging...
1) Unplug memory and plug it in other computer. Maybe you've got a bad memory.
2) Both memories must be of the same type, both PC100 or both PC133 or...
3) In a system with four slots place one memeory card in first and second in third slot so that memory interleaving can take place - will work slightly faster.
Ian
Minimum System Requirements for capturing miniDV
By darkwhite in forum ComputerReplies: 19Last Post: 27th May 2012, 07:21 -
Minimum System requirements for Bluray ripping/burning?
By orbital517 in forum Blu-ray RippingReplies: 12Last Post: 28th Oct 2010, 11:32 -
System Requirements to Rip/Convert Blu Ray
By minerva.thegift in forum Blu-ray RippingReplies: 5Last Post: 22nd Sep 2009, 23:16 -
Minimum system requirements to play 720p files?
By ukb007 in forum Newbie / General discussionsReplies: 11Last Post: 21st May 2008, 13:36 -
HD system requirements
By kippard in forum Newbie / General discussionsReplies: 25Last Post: 20th Jun 2007, 02:05
