ok here is the problem...i had win xp and i installed all my ati crap in the right order etc....my video in worked fine... i then reformat and install 2000. i once again install everything in the right order....(e.g. drivers,control panel,capture drivers, and directx8.1(not in that order...)). Everything works fine on the multimedia center except the Vido In program....i dont get an error or anything it just doesnt start...the mouse turns to an hour glass for a few seconds and nothing happens. Does anyone know of the problem? I had a similar problem w/ xp but i got an error pop up and it turned out that i installed the stuff in the wrong order. Thanks for the help. Keep in mind, i have a radeon 7200, NOT an all in wonder....![]()
well,i had a buddy with a similar problem and it was caused by win 2000 server.it wont run tv software.
Ati Radeon 3200 HD no overscan [SOLVED]
By carlos28355 in forum Media Center PC / MediaCentersReplies: 33Last Post: 9th Sep 2011, 10:38 -
ATI Radeon 4870 HDMI audio
By shorto in forum ComputerReplies: 6Last Post: 22nd Mar 2010, 20:56 -
ATI Radeon Pro 2400 to TV
By bulletb1331 in forum Media Center PC / MediaCentersReplies: 8Last Post: 27th Jun 2008, 14:52 -
Capture problem with ATI Radeon HD 2900 XT in Wondows XP SP2
By redrock1 in forum Capturing and VCRReplies: 3Last Post: 21st Mar 2008, 01:03 -
What do you think about the Ati Radeon 2600 hd pro?
By davidsama in forum ComputerReplies: 4Last Post: 18th Nov 2007, 15:25
