hi i recently downloaded tmpgenc and tring it out, but ive used it before in the past, but i never had a problem like this. when i get any of my files even files that i used on my old computer with tmpgenc and they worked it says that the file is unsupported or something in that nature can some one help????????????????????????
also it had a black screen when encoding does anyone know how to fix that if ti happens again to me?????????
Here are a couple of options.
1. I've heard that the LIGOS VFP in TMPGEnc 2.58 has issues. Try un-selecting it. You do that by going to OPTONS / ENVIRONMENTAL SETTINGS... Choose the VFAPI Plug-in Tab, unselect LIGOS. You'll have to exit / re-enter the program for the change to take effect.
2. Try loading the Cyberlink PowerDVD XP Demo. If you are missing an MPEG encoder, it's my understanding this provides one.
Good Luck.
Tivo Homer
AC3 Files with TMPGenc
By PHNeedsHelp in forum AudioReplies: 3Last Post: 4th Nov 2009, 12:37 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
changing ifo file names on same file ext of diff dvd files
By holliquinn in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2008, 05:02 -
Trying to Join separate files into 1 file, then add 1 more file and burn
By futureBDburner in forum EditingReplies: 2Last Post: 11th May 2008, 03:50 -
Audio files now show as "Winamp Media File" in file type
By tmh in forum AudioReplies: 3Last Post: 7th Jan 2008, 13:25
