i only get video when i try to convert a divx file to mpg file. Can anyone help me ?![]()
The reason for your problem is compression used in Divix file. To get around it use virtualDub
open the divix file
select direct stream copy for VIDEO
full processing mode for AUDIO and select no compression.
That might fix your problem. -
I have seen this question so many times and also replied a lot of time. Even in the conversion guide have a note about this.
Check this guide out "http://www.vcdhelp.com/tmpgenc.htm" and look for this note "If you get audio errors, out of sync problems or bad audio or no audio at all Try to convert the audio to wav before converting"
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 22:10 -
TMPGEnc DVD Author-sound?
By Mållgan in forum Authoring (DVD)Replies: 2Last Post: 14th Apr 2009, 06:51 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 17:12 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 17:00 -
TMPGEnc Plus and AVI sound
By busdonic in forum Video ConversionReplies: 5Last Post: 22nd Jun 2007, 11:18
