I am currently trying to encode "We were soldiers" to DivX 5 using a guide that says it is intended only for PAL not NTSC. How do I find out which one my vob files are?
I can't get the screenshot of the stats window from DVD2AVI to display for some stupid reason but it says the following
Aspect Ratio: 16:9
Frame Rate: 23.976
Video Type: FILM 99%
Frame Type: Progressive
So what would make a guide written for PAL different from a guide written for NTSC?
Originally Posted by DreamTFK
example VCD - PAL = 352*288*25 fps ---------- NTSC = 352*240*29.97fps (23.976 film)
Otherwise the guide should be compatible.
I am encoding to DivX 5 though, so can't I use a higher resolution that 352x288?
yes, you can use whatever resolution your heart desires. just don't go too high or else you will see some artifacts and that isn't good. When I make a DivX 5 movie i generally use, when the calculated bitrate is around 800-1100, 640x###. The ### being the right number to make the proportion(aspect ration) correct. Get a bitrate calculator to calculate your bitrate, the one here:http://www.divx-digest.com/software/advanced_bc.html will also calculate your proportion.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Whats the difference between these 2 MKV files?
By dave in or in forum Video ConversionReplies: 2Last Post: 11th Aug 2011, 15:44 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Divx or xvid? Whats the difference?
By szalaikornel in forum Video ConversionReplies: 3Last Post: 17th Jan 2009, 12:16 -
hdr sr12(NTSC) or hdr sr12e(PAL) any difference between them?
By deejay.2001 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Aug 2008, 16:28
