On several movies I've tried to rip, both SmartRipper and DVD Decryptor give me errors near the end of the rip, saying there's not enough disc space, when in fact there is. And another time only half the movie actually got ripped and it kept saying it was completed. Anyone else have these problems?
Only just started using DVD Decrypter, seems to be ok so far. I've never had any trouble using SmartRipper
sounds like your using the Fat or Fat32 file system which has a 4gb file size limit, you'll need NTFS to be able to create files bigger than this
Smartripper says it completed successfully but it chops off anything over 4gb so you lose part of the movie -
That sounds like it could be the reason, but when I've used DVD Decryptor to create an ISO file of a single layer DVDthe file is over 4 gigs and still works fine.
DVD Ripping, 4:3 and 16:9 Problem
By alimustafakhan in forum DVD RippingReplies: 2Last Post: 10th Jun 2010, 04:03 -
Problem ripping ET
By audax in forum DVD RippingReplies: 8Last Post: 27th May 2009, 18:19 -
CD Ripping Problem
By ThePMonkey in forum AudioReplies: 4Last Post: 25th Jun 2008, 06:47 -
Problem ripping CRASH
By vice86 in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2007, 09:27 -
DVD ripping problem
By borisblavasky in forum DVD RippingReplies: 3Last Post: 17th May 2007, 11:38
