I'm following step by step from using HP guides:
Since capturing from the PC-1`sony via Firewire on Adobe Premier7.
And converting the .AVI to SVCD with TMPGencode respecting the "How to" guide to TMPGenc. http://www.vcdhelp.com/tmpgencsvcd.htm
When the image is still, the quality is amazing....but when moving, it seems to be in slow motion, like if it was skiping frames or something. Also, when film is in motion some horizontal lines appears surrounding the objects - some kind of interference.
What am I doing wrong? I've tried almost everything.
If you run your bitrate too high the DVD player will "stutter" possibly causing the problems you describe. The "Interference" is interlacing and would normally be hidden by the TV at full speed.
So it's likley that you will need to re-encode at a lower bitrate. -
Thank You very much for your help.
Ok. I'll try a low value in the bitrate setting.
About the INTERLACE. All those problems are seen on TV.
What should I do? Choose Interlace or Non-interlaced(progressive) at the TMPG setting?
About Top Field Order - A or B?
I thought the bitrate was related to the SVCD quality, so I set the maximum.
TKS again snowmoon. -
in all encoding larger bitrates have better quality mos tof the time, but SVCD is physically limited to ~2500kbps.
Slow Motion Effect
By leedownen in forum Video ConversionReplies: 5Last Post: 13th Feb 2008, 01:16 -
Make slow-motion
By David_UK in forum Newbie / General discussionsReplies: 15Last Post: 28th Nov 2007, 00:44 -
Slow motion
By Pliny in forum MacReplies: 7Last Post: 7th Aug 2007, 00:02 -
Which casmeras are best for slow motion?
By Deathwish in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 2nd Aug 2007, 23:04 -
Slow Motion
By sbuckmybballs in forum Newbie / General discussionsReplies: 6Last Post: 21st May 2007, 02:16
