  1. Hi, I am wondering did someone try to encode using CCE 2.64 rather than 2.50? Did you check safemode? If you did than how long was the procedure. Since manual says if you are using 2.64 then check safe mode and it will take considerably long. Thanks
    Nov 2001
    Sweet Home Alabama USA
    Yes, ONCE. It did take significantly longer with safe mode and it didn't look any better than 2.50 so I use 2.50.
