I have made my first SVCD using Ulead and it plays back OK on my PC. My DVD player is a combination laser disk and CD DVD player and is not on your compatability list. However the manual says it will play a Video CD which I assume is the same as a SVCD. Howver I cannot get it to play back. When I look at the disk I made it has a number of folders but nothing in its root is this correct. I apologise that this is a very basic question.![]()
some dvd players will not play svcds but will play vcds. try making a vcd. if you got videostudio 6 you can make the vcd. you can also try to just make a mpg in vcd or svcd format and use nero to make a vcd or svcd and see it that works.
Why does one dvd made with ConvertXtoDVD play and another doesn't?
By Hal05154 in forum Authoring (DVD)Replies: 6Last Post: 26th Mar 2011, 00:29 -
Can't play audio from avi made from mkvtovob for ps3
By User81 in forum AudioReplies: 1Last Post: 25th Feb 2011, 04:45 -
DVD Made on Your Recorder Play on Another Brand?
By retexan599 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 19th Jun 2008, 13:12 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 21:03 -
Pioneer XV-DV313 will only play back up copies of dvd's, not originals?
By moults in forum DVD & Blu-ray PlayersReplies: 6Last Post: 6th Aug 2007, 15:17
