I'm backing up DVD movies to DVD-r and DVD-RW, using the following steps:
1. Rip with Smartripper (followed by DVD2AVI) or with CLAD
2. TMPGenc, output to the largest file possible (adjust bitrate to fill the disk) to creat MPEG2
3. SpruceUp to create Video_TS files
4. Gear Pro DVD 6.0 to burn
The discs play without problems. BUT: I expected better picture quality than this from a DVD. In Monsters Inc or Shrek, I get pixellation or blockiness during sequences with rapid movement.
In 'film' movies (as opposed to digital movies), I get jaggies (jagged edges) during movement sequences. Any ideas/suggestions, or is this as good as it gets for now?
My system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
2x512 MB DDR 500 ram
WinXP Pro
ATI Radeon X800pro
5x120 GB Western Digital ata100
TDK Velocd 48x16x44
Sony 8x DVD burner -
What is your MAX bitrate? Limitation in peax bitrate is ususally what causes pixelization in some scenes. Animated moveis are also harder on encoders ( I've spotted blocking on the shrek DVD ).
Cheers -
My bitrate is around 3000 K/s
I forget whether that filled the disk or not. I'll try re-encoding it at the max possible bitrate.
Blackhawk Down and Lord of The Rings were encoded at slightly lower bitrates, because they exceeded the Disk capacity (around 2800 k/s)My system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
WinXP Pro
ATI Radeon X800pro
TDK Velocd 48x16x44
Ok, I think I see the problem here...
Use 2-pass set min to ~1500 and max ~7000 and set Average bitrate to the calculated bitrate to fit it on one disk. This will produce perfect output results that will never be blocky. -
Using 2-pass with appropriate bitrates you might be able to fit 2 movies per disk. As long as the average bitrate is not too low.
Thanks for the reply.
Now (I'm not at my home pc at the moment, so forgive the stupid question): where is the 2-pass set? Is it in TMPEGenc ?My system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
WinXP Pro
ATI Radeon X800pro
TDK Velocd 48x16x44
Sony 8x DVD burner
Poor Picture quality - need help!
By Martin747 in forum EditingReplies: 2Last Post: 26th Dec 2010, 12:00 -
DTS Express PiP (Picture in Picture) / BD Rebuilder question.
By rippn in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2009, 16:41 -
Question regarding DVD picture quality
By Neutral-Sage in forum Authoring (DVD)Replies: 7Last Post: 5th Nov 2007, 18:34 -
Picture Quality Question on made DVD
By Superstar24 in forum Newbie / General discussionsReplies: 24Last Post: 26th May 2007, 00:35 -
picture quality
By nexous in forum RestorationReplies: 4Last Post: 18th May 2007, 04:03
