I am using Flask to rip directly from a DVD using the SVCD settings
I have found the blocking on fast moving objects is worse than VCD? You can notice it on the computer but even more when I make a SVCD with the file?
Do I need to tweak the settings?
I also notice that the SVCD settings give a video shaped box which is longer than the width but when made into a SVCD it looks fine??
The file I have is 4min 59 sec - 99.4mb long. Is this the correct length for SVCD?
Is there a small program that can check what the file is (Mpeg 1 or Mpeg 2) as im never sure its been done correctly?
Any help would be appreciated
Results 1 to 1 of 1
SVCD edit
By monarols in forum Video ConversionReplies: 3Last Post: 15th Jul 2008, 18:48 -
Svcd Burning
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 16th Apr 2008, 09:25 -
How do I split a SVCD
By VoXiSo in forum EditingReplies: 1Last Post: 4th Feb 2008, 16:14 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 15:17 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
