I'v been using SoundForge to downsample the wave files ripped from DVD. Is there another program that will do the same thing as SoundForge?
goldwave will do this, as will ssrc.exe (shibatch sample rate converter, a command line program that can be used as a 'plugin' to TmpGenc)
ssrc is the best program for that - there is even a GUI for it ..
http://shibatch.sourceforge.net/
http://www.doom9.org/software2.htm#audio -
WOW, that was fast! Thanks for the replies. My PC is acting wierd and SoundForge will only run once and I have to reinstall it.
SSRC is the simplest. Just copy ssrc.exe to the folder with the wav in. Open an MSDOS box and paste the following:
ssrc --rate 44100 input.wav output.wav
Just substitute the filenames.
Was I supposed to get soundforge 10 with Vegas 9.0?
By solarblast in forum AudioReplies: 0Last Post: 13th Mar 2011, 22:50 -
Resampling audio
By siluet in forum Newbie / General discussionsReplies: 5Last Post: 19th Oct 2009, 11:24 -
Copying CD track with Vegas, SoundForge, Nero, ...?
By solarblast in forum AudioReplies: 8Last Post: 29th Aug 2009, 01:21 -
How To Replace Audio with CDAudio on MusicVideos(Soundforge)
By Sartori in forum User guidesReplies: 5Last Post: 19th Jan 2009, 19:41 -
avi sound editing in Soundforge
By maxWsax in forum AudioReplies: 6Last Post: 31st Mar 2008, 02:54
