Hi:
I use DVD2SVCD 1.0.9b3 and I'm having a 'little' problem.
When converting any DVD DVD2SVCD uses 796MB for bbmpeg file size when creating mpg files for CD800.
My problem is that it doesnīt fit in a CD800 (when burnign with Nero, at least).
I have tried to mux again from the .mp2 and .mpv files and configuring bbmpeg for 794 and it works and it fits.
But my problem is: How can I tell bbmpeg to use always 794 and not using 796.
The .ini file is created avery time I use DVD2SVCD so I have to stop after encoding and muxing using bbmpeg.
Any help?
Thank you.
Javier
There is a CD size setting in DVD2SVCD, also you can set the value in BBMpeg and then set that as the default setting, though this may be overridden by the INI file.
Thank you, but ....
Where is this CD Size setting for bbmpeg in DVD2SVCD??
I canīt find it.
getxo17. -
You have to open BBmpeg manually, set the max size, then save current settings as default. There are menu buttons for the save, I think under the program tab.
Again, the ini file may override this, I'm not sure on the new version of DVD2SVCD how to set this, but there used to be a CD size setting on the main screen.
LCD Monitor Screen Size, bigger isn't really bigger?
By Des in forum ComputerReplies: 13Last Post: 27th Dec 2011, 15:13 -
Error: File shorter than expected
By justin79 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 15th Jun 2011, 23:55 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 21:48 -
Hi all, I need program to batch de-multiplex mpg files with 2 audio tracks
By mmdmmd in forum AudioReplies: 4Last Post: 14th Oct 2008, 16:57 -
Report: FCC expected to rule against Comcast
By TaoTeWingChun in forum Latest Video NewsReplies: 1Last Post: 28th Jul 2008, 10:52
