Hi all, I have been reading the How to convert DivX to VCD page recently, and was wondering: If I have a large video (over 80 mins) and want to split it into two, do I have to split the audio dub file into two parts as well?, if you know what I mean.
EDIT: And how would I do it?
Originally Posted by jbartone
see this to do the editing: http://www.vcdhelp.com/tmpgencedit.htmwhat are you askin' me for...
I'm an idiot! -
You ought consider squeezing an 80 min movie onto one 80 min CD by slightly lowering the video bitrate (like 1100 instead of 1150) or going for 128 kbps audio bitrate, but if you dont want to sacrifice quality, using TMPGEnc, select source range and encode first the first half, then the second. (Adjust the split point to a scene change in the vicinity of half the movie.)
The audio and video will be split simultaneously.
If you decite to split over 2 CD's, then you can actually raise the video bitrate to get better video quality.
(All this bitrate tweaking leaves you with out of specs VCD, a.k.a. XVCD - not supported by all DVD's).
/Mats
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 03:55 -
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 08:25 -
Divx to VCD
By d_unbeliever in forum Authoring (VCD/SVCD)Replies: 16Last Post: 30th Apr 2009, 00:19 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 12:28 -
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01
