the problome is i play this mpg movie in windows media player
and it work then the day after i play it again and it dosn't and it's the same
movie.the WMP show this error:
Cannot open. Please verify that the path and filename are correct and try again. (Error=80070005).
i didn't change the path or the filename why it's happen
any1 can help please i use WMP 6.4
If this happens for every MPG you play, I don't know what could be going on. You might try a different player, like Zoom player (excellen/free/powerful). Can you still cut and paste these files that will not play in WMP? I'm wondering if something is happening that is not allowing you access to these files with the file system of Windows (happens sometimes, REALLY annoying)
Let me know how it turns out
Prospero -
this happends sometimes when you install or uninstall a program that modifies the directshow filters. i use to get this problem all the time when i use to experiment with a lot of new software. i never found a fix. so i make sure i do two things.
1 install media player first, i actually just started this since wmp 9 came out
2 only install software that you know you need and that you plan to keep installed.
i usually reinstall windows(from backup) once maybe twice a month sinse i like that "store bought response" that you get after a fresh install. but when i was trying out all those different type of software, i would get so frustrated with media player that i was reinstalling one or two times a week.
DirectVobsub and WMP 12
By mrcoolekin in forum Software PlayingReplies: 4Last Post: 27th Apr 2012, 03:49 -
Wmp
By aaahza in forum Software PlayingReplies: 1Last Post: 23rd Feb 2011, 04:03 -
WMP 11 Problem
By leebo in forum Newbie / General discussionsReplies: 14Last Post: 17th Apr 2008, 19:15 -
WMP
By marlo in forum AudioReplies: 0Last Post: 23rd Nov 2007, 16:50 -
wmp trouble
By ssaamm in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2007, 20:03
