I'm using VirtualDub 1.4d and the Studio DC10Plus card to try and do VCD quality captures. I set the custom frame size to 352x240, and when I start the VCR tape, it always appears cut off on the left and right edges. Does anyone know why it would do that?
I don't have the same problem if I set the resolution to 480x480 (i.e. SVCD).
Lyman Green
You MUST capture in either 320x240,
640x480, 640x320 or 320x240 (or a bit smaller
if you crop) and resize to the desired
size.
You cannot do custom capture sizes with a DC10.
OK, to answer some of those questions...
1. To the first replier: Disk space. I would prefer to capture in the format I want because I will run out of disk space. Yes, it's something I need to solve, but at the moment, I can't. I've only got about 10GB to write to.
2. To the second replier: I do not think you are correct. I have been able to capture to other sizes (specifically, 480x480) with VirtualDub 1.4d, setting the 'custom' frame size. If it isn't working, you sure could have fooled me.
On the other hand, it takes up a lot of space to capture in 480x480 (i.e. more than if I capture in 352x240).
But, on to the next question - if I WERE to capture at one of the default rates (say 640x480) how do I use (for instance) virtualdub to convert that to the size I want? And will it do it without losing info or hurting quality? -
I stand corrected -
The DC10 will capture in 480x480 with VirtualDub.
A few issues though:
Does Virtual Dub handle the 73 minute bug or will
I start dropping frames like crazy after 73 minutes ?
MP20 Capture Card and Pinnacle Studio 14
By egee17 in forum Capturing and VCRReplies: 0Last Post: 26th Feb 2011, 19:30 -
Would more ram help with playback issue in Pinnacle Studio Plus 12 in vista
By yoda313 in forum EditingReplies: 28Last Post: 11th Jun 2010, 19:40 -
Can I capture DVD to edit? Pinnacle studio 12 ultimate
By photonianpa in forum EditingReplies: 1Last Post: 5th Mar 2009, 05:29 -
Pinnacle studio 11 capture problems...
By bla4free in forum Capturing and VCRReplies: 0Last Post: 6th Feb 2008, 10:09 -
Pinnacle studio 8 capture problems
By bimfi in forum Capturing and VCRReplies: 1Last Post: 23rd Nov 2007, 15:27
