I think this is the right forum for this question so I will ask here.
I have a burner on one computer networked to this computer. The CD-RW on the remote computer shows up in "My Computer" along with everything else on my computer as a networked drive.
I was trying to use Nero to access this drive, but it doesn't recognize it. Is there a way I can make it recognize that drive in Nero, or is it even possible?
Any other software known to do this?
I am using Win98SE.
Thanks.
Well, I think I've heard of software that can run in a client-server setup to provide remote access to a burner, but no, you shouldn't expect that to work. A burner mounted as a remote drive will only be usable as a CD-ROM.
If you really want to do the burn remotely, run Nero (or whatever) on the machine with the burner and just access the files over the network. Burn at low speed if you do that, though, and copying the files over would definitely be better. -
4 things you can do.
1) Setup the remote with a UDF packet writing formatted
CDR or CDRW and map as a network drive.
2) run a macro system to auto burn files copied from a remote
computer to the local cdrw system's drive.
3) upgrade to an XP based network (with built in support for networked cdr)
4) browse amongst the various remote cdr file storage software solutions. -
here at work we have mapped network drives and we use the drive letter pick data to burn in EZ CD Creator.
We haven't burned any coasters. -
I have a similar setup at home - my daughter's digital pix are on one computer and the CDR/W burner is on the other. I turn on both computers, sit down at the computer with the burner and mount her hard drive as a network drive, and burn away. I usually burn at 6x or 4x and its a 100 Mbit network with only 2 computers so I don't worry much about the network being too slow to keep up with the CD burner. I have yet to make a coaster burning over the network.
CogoSWSDS
Can't use one of my XP pc's on network (Network experts)
By neworldman in forum ComputerReplies: 5Last Post: 21st Jan 2011, 15:12 -
network expansion?
By Xylob the Destroyer in forum ComputerReplies: 10Last Post: 7th Dec 2008, 18:31 -
Network printer on separate network?
By Lucifers_Ghost in forum ComputerReplies: 7Last Post: 5th Dec 2008, 13:52 -
burning over a network
By Hal05154 in forum DVD & Blu-ray WritersReplies: 3Last Post: 7th Aug 2007, 13:11 -
Setting up a network
By bballnut in forum ComputerReplies: 6Last Post: 2nd Jun 2007, 15:31
