need lots of help
well i would just extract it with "isobuster" ... but there are other methods ..
VCDEasy is awesome for this!! It has a built in utility to rip mpeg from the bin file and then you can play in any software decoder as long as you have the necessary codecs. hope it helps.
when i go to laod the vcdgear i get a messsge that says
( plese verify correct file name that was given) or source file could be opened or accessed what have i done wrong ? -
open the .CUE file in notepad and make sure the filename in there matches the filename of the .BIN file.Originally Posted by vesterlee
How to put dvd's onto portable harddrive & play on tv?
By frangapanni in forum Newbie / General discussionsReplies: 1Last Post: 14th Aug 2011, 02:05 -
Can you put a nas on a normal usb harddrive?
By yoda313 in forum ComputerReplies: 2Last Post: 19th Feb 2009, 19:03 -
How to put a new audiotrack on a MPEG file?
By Safidk in forum EditingReplies: 5Last Post: 28th Oct 2008, 17:35 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 12:58 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11
