trying to get my .avi file "coded" with DivX codec so I can use TMPGE to convert to MPEG. What do I need to do specifically with the DivX PRo program to make this possible?
Have you tried using the TMPGEnc wizard and just re-encode your original AVI file? It should take a straight AVI and put it out in whatever MPEG format you choose.
If you are missing codecs to read or view your AVI, try downloading the NIMO codec pack from http://www.btinternet.com/~nimosiro/ Load it using the basic option.
Good Luck.
Tivo Homer -
can you play the avi in windows media player? if so, then you don't need to do anything else in order to convert it.Originally Posted by Cmonteith
try the Nimo codec pack as Homer says if you can't play the file.
if that doesn't work, load the file in virtual dub, and under file-->file properties, and see what codec it needs.what are you askin' me for...
I'm an idiot! -
Great forum here. Helped me before having to post my question.
Thank,
Randy -
i dont totally understand what it is you're trying to convert the avi file to. is it mpeg1, 2, 4? i.e are you trying to make a vcd,svcd or a divx file?
What was said above...Originally Posted by Cmonteith
Also see this
http://ww.vcdhelp.com/forum/userguides/116924.php
Difference between divx and xvid, and the best codec available?
By acommuter in forum Newbie / General discussionsReplies: 33Last Post: 10th Aug 2012, 02:57 -
What is divx and xvid codec?
By Azrail in forum Newbie / General discussionsReplies: 4Last Post: 5th Oct 2010, 22:31 -
DivX and xVid codec
By cheerful in forum Software PlayingReplies: 9Last Post: 10th Jan 2010, 22:55 -
Is there a free DivX codec for Dr.DivX?
By Djard in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 04:33 -
Best free DIVX codec?
By DonGallego28 in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2007, 19:45
