WARNING !!
There is a NEW worm virus spreading the internet.
It will grab all your email addresses in your contacts and will send a pif file to all of them and when they open the file it will happen to them as well. I had 10 emails this morning trying to do this 2 me.
The Worm is cunning it grabs a file off your computer infects it, renames it to e.g ( letter.doc 2 letter.doc.pif )and posts itself over the net.
There is a message on the email which is:
"Hi! How are you? I send you this file in order to have your advice See you later. Thanks"
If you recieve this email delete it as soon as possible
Just thought you might want 2 know.
Widge
You should change your Explorer settings so you can SEE the file extension.
Open Windows (File) Explorer
1) View Menu selection
2) Options
3) View Tab
4) Uncheck the: "Hide MS-DOS file &extensions for file types that are registered" checkbox
5) And select the: "Show all files" Option button
Thats for Win95.
WinME is Tools, Folder Options, View etc.
98 is either like 95 or ME.
Warning BD+ Mey Not Have Been Removed
By wulf109 in forum Blu-ray RippingReplies: 10Last Post: 7th Feb 2012, 16:04 -
Need Help With An Avast Warning
By hech54 in forum ComputerReplies: 9Last Post: 21st Feb 2010, 03:18 -
funny warning sign
By freebird73717 in forum Off topicReplies: 0Last Post: 20th Aug 2009, 19:26 -
Standard TV warning
By djmobius in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 24th Jul 2008, 07:10 -
Warning: implode()
By handyguy in forum FeedbackReplies: 1Last Post: 24th Aug 2007, 13:02
