I've been successfully using ATI MMC 7.1 with an AIW 128 card for almost a year now to record MPEG-1 files (using very helpful instructions I found on this website). Recently, MMC has started forgetting which audio input is the correct one to use. I have re-run the installation wizard from the display tab of settings multiple times to set the correct audio input, but when I exit and re-enter the TV application, the setting reverts to the default. I've even tried changing the registry setting (HKEY_CURRENT_USER\Software\ATI Technologies\Multimedia\Features\TV\Sound), but every time I exit the TV application, it resets.
I can't figure out why this has suddenly started happening or what to do about it. Recent changes to my computer have included a new monitor, a switch from DSL to cable modem, installation of back up and FTP software, and installation of one old CDROM that wanted to install quicktime 2.1 but I didn't let it. I can't see why any of these should have affected ATI MMC.
Any ideas? I've missed multiple TV recordings because of this.
Thanks very much.
ps: my system is WinME, AMD Athlon 1200Mhz, Abit KT7A motherboard, and MonsterSound MX300 sound card.
start MMC
open windows volume (yellow speaker or via control panel/sound/advanced)
click options/recording
select source and volume level
close MMC
then it should stay
MMC has its own copy of the settings, and loads and unloads them with the program -
Thanks. I tried what you suggest, but it didn't help.
It also doesn't explain why, after a year of working correctly, it suddenly stopped working.
Any other ideas?
Thanks.
Videosoap in ATI MMC. Couple of questions
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 13:49 -
Anybody know how to get ATI MMC version 9.02???
By pukhog3 in forum Capturing and VCRReplies: 10Last Post: 10th Sep 2009, 18:12 -
How to use ATi MMC Multimedia Center TV
By c627627 in forum User guidesReplies: 2Last Post: 8th Apr 2009, 04:14 -
More ATI MMC questions. (I RTFM'd.)
By palouse in forum Capturing and VCRReplies: 5Last Post: 13th Jun 2007, 21:08 -
where to download old ATI MMC?
By mencius in forum Capturing and VCRReplies: 2Last Post: 23rd May 2007, 00:44
