Hello, i tried to convert using tmpgenc so i could then burn, but it wouldnt open the file. Does anyone know how i can convert a mov. file so i can burn it?
thanx
jeff
Read the FAQ, NEWbie, & Convert sections
Panasonic DMR-ES45VS, keep those discs a burnin' -
Radtools for the video, just convert it to an avi, and goldwave for the audio, just convert it to a wav.
nightonearth73-
yes, you can use TMpgEnc to convert MOV videos..
first, you must already have installed a version of Quicktime for Windows.. it doesn't matter which version (4,5,6) as long as that version has the appropriate codecs for the video you're trying to convert.. if you dont have any version of QT installed, you might as well install version 6 as you will get the latest codecs. that way, you'll be able to read all the latest MOV videos.
now download the VFP QTReader plugin for TMpgEnc over here (it's only 40k):
http://www.geocities.com/SiliconValley/4942/svcd.html
add the QTReader.vfp file to the TMpgEnc main folder.. and it should now show up as a checked item in the options screen (under Options/ EnvironmentalSettings/ VFAPI Plugins Tab).
that should do it.. now you'll be able to read/convert MOV videos directly from TMpgEnc.
quick note: once you have loaded the MOV video into TMpgEnc, make certain that you check and/or set the Frame Rate correctly. for some odd reason it doesn't set automatically (at least not for me), and if you dont have it set correctly then the resultant MPEG/AVI might not play right from MediaPlayer. I always double check this by loading a MOV from the Quicktime Player, verifying the Frame Rate and Frame Size (and that reminds me, dont forget to check the frame size, and make sure that's correct, too :-)
-s.
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 08:42 -
decode/decrypt mp3,mp4, ipod, mov etc to avi to burn to dvd
By brightpenny in forum Video ConversionReplies: 1Last Post: 16th Sep 2009, 17:24 -
Converting (Quicktime) .MOV file to .WMV file
By stanislawski in forum Video ConversionReplies: 2Last Post: 6th Feb 2008, 19:19 -
Burn .avi file to VCD while still retaining subtitles
By Holymoly in forum Video ConversionReplies: 1Last Post: 12th Dec 2007, 22:30 -
Best way to convert .mov(QT) file to an .avi file...... is?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2007, 22:05
