I am trying to have three eps of Futurama on one CD, they are already coded as MPEG1 for VCD, now, I want to make a menu so when it starts up I can select which MPEG I want to play ( or more like which episode I would like to play ), which software should I use. I have tried DVD Movie Factory but I can not figure out how to attach each MPEG to each icon so when I click on it it will start the movie. I also tried the DVD Workshop & that one I can not get to do the same thing.
Any ideas on how to do this?
Thanx
"Computers are stupid, but they are capable of being stupid one million times per second"
There are guides to creating VCD menus in the "Authoring" section on this site. The short description is that you create a JPG (in any program you want) and convert it to a VCD still, or create an MPG clip for the menu. Then you set up the PBC (in VCDEasy, for example) when you author the disc so that the number keys are linked to your clips.
In MF You only must have all clips selected (highlighted), when starting authoring menus and it will do everything for You. You may only want to change icons.
burn multiple dvds with original menus
By pins123 in forum DVD RippingReplies: 1Last Post: 26th May 2010, 16:31 -
Multiple subpic aspects on still menus?
By EddyH in forum Authoring (DVD)Replies: 11Last Post: 29th Apr 2010, 09:43 -
Multiple Start Menus
By thecoalman in forum ComputerReplies: 4Last Post: 23rd Apr 2010, 10:43 -
how to create multiple menus
By shashgo in forum Newbie / General discussionsReplies: 0Last Post: 12th Dec 2008, 15:02 -
Multiple Audio Titles With DVD Menus
By GiLGiJ in forum Newbie / General discussionsReplies: 1Last Post: 18th Apr 2008, 14:17
