i know must extract bin and cue but i am new to this stuff. i want to watch on my computer and then. i have 2 files that say cd1 and cd2. i open them and there are all these rar files when i open cd1. i double clicked on the first rar file and i see a bin and cue what do i do with them to be able to watch on computer? can i use vcdgear and if so how do i use it?
Results 1 to 16 of 16
hmm, wel, CUE and BIN files, are in fact some sort of ZIP files, you need to sort of "unpack" them to watch them on your computer...
therefor, you will need a program
get one there, that will unpack your CUE or BIN to MP(E)GWanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
You cant, well you can but you have to burn them first. Then you will actualy have the cd with the files on it. what a bin file is realy is the copy of the image on the cd and the cue is just what tells the burner how to burn it. So you will need a burning program that does bin/cue burning I recomend Fireburner. You can easily get it on KaZaA.
*pardon my english, I dont take the time to type right.*
___insert witty, well writen, thoughtthrough comment here___ -
O whait I read your message again and I was wrong what you need to do is get WinRar and highlight all of the files in cd1 or two and right click and select extract with winrar and select were you want to put them and that should work sory for the rong advice.
well you should have your files no matter what kind they may be what you do next is up to you will probably get a mpeg of cd 1 and cd 2 but im not shur becaus im not shure what the files hade to begin with
it is cd1 and cd 2 but 2 doesnt have a cue file. i have it extracted how do i convert to mpeg?
Use CDMage (you can find it in the "Tools" section to the left), or use VCDEasy (> Tools>(S)VCD Build/Rip)
You can't fool me, I'm a moron! -
is there a guide for using vcdeasy if so send link
thanks for all the help guys -
still having problems with this . i used the cdimage and it will not extract the file from the mpeg folder. what is wrong or what can i do to fix this. i am trying to convert the bin or cue file to mpeg.please help.
there's an easier way...
once you've gotten the bin and cue files, get a program from the tools section here called daemontools. that will let you mount the discs as virtual discs on your hard drive, and you can treat it as if it were a real CD--watch it, copy it...what are you askin' me for...
I'm an idiot! -
Using CDMage:
Load your .BIN file - select M2/2532 as image type
Expand the "track 1" directory (left-side pane) - click on the MPEG2 ( if SVCD) or MPEGAV ( if VCD) folder
In the right-side pane, right-click on the AVSEQ.xxx file, and select "extract"
Using VCDEasy:
goto Tools, select '(S)VCD Build/Rip'
bottom half of screen is "VCDxRIP"
click the "BIN/NRG file" button to load your .BIN file
Click the "XML file" button; enter any name/location
Click "Rip" button.You can't fool me, I'm a moron!
How to watch HD .mov files on computer
By kaisaka in forum Newbie / General discussionsReplies: 5Last Post: 30th Mar 2011, 13:10 -
need to watch verizon fios tv on my computer
By greendesert in forum DVB / IPTVReplies: 0Last Post: 27th Jul 2010, 10:08 -
svhd to watch on my computer
By poolboy314 in forum Newbie / General discussionsReplies: 3Last Post: 13th Feb 2010, 15:00 -
Can I watch a PAL dvd on my computer?
By dredle1 in forum ComputerReplies: 7Last Post: 9th Oct 2008, 23:18 -
watch dvd movies on computer
By jfmalone in forum Software PlayingReplies: 10Last Post: 13th Feb 2008, 17:30
