Results 1 to 9 of 9
  1. Great tool to make vcd and svcd i have a philips 711 dvd player and after many times making svcd this is the first time that i make one that works perfect fast forward all is
    working fine.
  2. Its make perfect rips but you have to kill your DVD drive, thats not a good trade.
  3. Rip to HDD first using Smart Ripper or DVD Decrypter.
    Aug 2001
    Pittsburgh, PA
    How does this method "kill" your DVD drive? How is ripping a movie different from playing it normally?
  5. When you do it dirct from the drive, DVDx rips and converts the files on the DVD at the same time. I order to do this the drive is constantly having to stop & start so causes excessive wear and tear. Imagine if you were to contantly turn on and of an ordinary household light bulb you would soon blow it. Same principle here really. Best of using somthing like CladDVD or Smartripper and then using DVDx.\
    <font size=-1>[ This Message was edited by: midiman on 2001-08-17 08:40:56 ]</font>
  6. t1955feb: So you have made an SVCD which does FF/RW fine on your Philips? You would be the first person I read of to accomplish this. I hope so...
    The important question is: How long is your SVCD in minutes?
  7. last movie ripped Red Planet in svcd DVDX on 3 cd,s plays on my philips 711 perfect only one bug in the program the movie is mono so no stereo for this time.
    This is the first time i can fast forward my svcd and is nit going back to the dvd intro screen.
  8. What program does DVDx use to encode? I've been using DVD2SVCD (I really like CCE over TPMPGenc) but it has problem with subtitles.
  9. DVDx does it's own encoding, it doesn't use any other program, it's a sort of a All-In-One program, and yes I agree that ripping from the DVD directly could shorten its life span, I also recommand you rip the DVD to the HDD, disable the ASPI in DVDx and encode from the HDD, just remember to also rip the IFO file of the movie.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
