I've tried burning VCD from avi file and mpeg file. I noticed slightly better quality from the avi file. How come I keep reading that VCD uses the mpeg format when I had no problem using avi? Is there some reason I should burn from mpeg file rather than from avi?
A VCD uses mpg format videos...the reason that u can burn using an avi is that your burning software is converting (encoding) to mpg before it actualy makes the VCD.
Most people like to use TMPG or another software to convert to mpg before burning because it gives them more control and the ability to tweak the settings on the mpg....Also if you view the mpg first and the audio in sync and the quality is good then the resulting VCD will be good...but if the audio gets out of sync when the burner converts it...your VCD will be out of sync..
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 00:56 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
how to convert and burn avi to vcd with cusoft
By brandon334 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 21st Apr 2008, 18:49 -
Burn .avi file to VCD while still retaining subtitles
By Holymoly in forum Video ConversionReplies: 1Last Post: 12th Dec 2007, 21:30
