Hi Guys
My first post and so just want to add my useful tips to this site.
If you have a load of jpgs that you will be making a slideshow out of then I suggest you do this for the best possible picture quality.
If your PC has a TV out card, then run a slideshow program on your PC and record the output onto DV. Capture this AVI in something like premiere and then encode it using tmpgenc.
You'll get pretty impressive results.
I was used to using the Adobe premiere method of importing the pictures and let it create a transtion in-between but this really does affect the final results.
Hope it helps.
Results 1 to 1 of 1
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 04:18 -
Looking for tips on use of ASFbin
By Seeker47 in forum Video ConversionReplies: 0Last Post: 22nd Dec 2010, 12:23 -
Lightscribe Tips
By jsmithepa in forum MediaReplies: 33Last Post: 13th Aug 2010, 13:41 -
Need Rendering Tips!
By reece_wallace in forum EditingReplies: 1Last Post: 31st Dec 2009, 01:15 -
pc tips n trix
By allenstreet in forum ComputerReplies: 3Last Post: 22nd Jul 2009, 20:41
