  1. my pioneer 104 wont play NTSF Region 1 films , can any one advice me on this topic. Just says playback of content from this region is not permitted?
    Dec 2001
    USA
    You need to set your Drive to region 1. But if you live in another region you will only be allowed to change the region 5 time before it will not play anything. You will need to look for away to make your drive region free, then you will be able to play all regions and not have to change region settings.
    May the force be with you.
  3. Hi mechmanuk,
    All you need is the soft "DVD Region-Free".
    It allows you to watch all region DVDs on any DVD drive( especially RPC2 ) even if it has been locked.
    You don't need hack DVD drive( flash firmware ) which is sometimes dangerous, useless or unavailable.
    DVD Region-Free also disable region check for popular software-based DVD players such as PowerDVD, WinDVD and CinePlayer.
    Other features include Region-Free for RCE DVDs, Macrovision-Free, Operation-Free, Direct-Play main title, and run self at DVD players startup automatically.
    You can get it at http://www.dvdidle.com/download/DVDRegionFree11.exe
    Best Regards,
    Fengtao
    DVDFab - Copy DVD and Blu-ray Disc to DVDR, BD-R, MKV and iPad/iPhone/iPod.
    http://www.dvdfab.com
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    fengtao - isnt that program you are selling like 40$ ?
  5. thankyou, thankyou, thankyou, it works all i need to do is buy it,lol glad someones replied it was doin mi head in.
    cheers m8
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    You can also change firmware or try scavenger.
    http://www.vcdhelp.com/play#dvd
