hello,
I trying to convert my first DVD to DVD-R. First, I used smartripper, but there were alot of programs with different length. The entire movie is around 3 1/2 hours longs. I was confused with how to pick which programs to rip. I saw the guide in this forum to use dvd2avi and rempeg2 for vob's larger than 4.5 gibs. When I get my .m2v and .wav files from the dvd2avi, how do I convert them back to vob. How do I create a new .ifo files for the new vobs? Am I on the correct path?
Yes, I am a newbie to this type of conversion.
Any advice is greatly appreciated,
Rage
First, read all of the guides on this site and doom9.org. Which movie is it?
I personally use DVDDecrypter to rip the movie to the HD. After that use Ifoedit to strip the streams. If the movie is under 4.3 you're fine, just burn. If it's over, then use CCE or rempeg.
how to convert dvd with dts audio to a dvd playable on a dvd player
By flannob in forum Newbie / General discussionsReplies: 5Last Post: 19th Sep 2010, 07:46 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 02:35 -
trying to convert old vhs tapes to dvd, used sony direct to dvd, not good
By hygieneboy in forum Capturing and VCRReplies: 27Last Post: 4th May 2009, 14:57 -
Convert PAL 16x9 DVD to NTSC DVD w/ Procoder - Less Image-More Borders Why?
By tubularusa in forum DVD RippingReplies: 15Last Post: 5th Aug 2007, 02:26 -
How do I convert double sided dvd to dual layer dvd?
By acid_burn in forum DVD RippingReplies: 2Last Post: 22nd May 2007, 05:04
