After ripping/ backup a DVD i got all the files, m2v, ac3 and spc files etc. How do I put the subtiles back on again, I use DVDSP to Author a DVD-R/ DVD-RW but DVDSP canīt import spc files only spu files, is there a way to convert subtiles files or is there a way at all to fix this problem.
I hope there is a way to fix the problem!!!!
I have another import problem with DVDSP, m2v files"bad format" i use Mpeg append to fixit or I can convert it to DVPAL with mm2c and then convert it back to a m2v this fix it, to but it takes forever to do this! is there another way to fixit and what this is problem! Only some m2v files has this problem, are there somthing wrong with the extractor program or do I extract the files wrong? I use DVDbackup, extractor, osex and yade (OS9)
Please help me.
I don't know how to do the subtitles in DVD SP, but I do know you can fix the "bad format" error by using the program MPEGAppend to correct the timecode in the m2v file.
You can get a trial version (7days) of MPEGAppend for OSX here:
http://homepage.mac.com/DVD_SP_Helper/Commerical/MAOSuX.html
This proggy has helped me so much, I ended up forking out the 30-some odd dollars for it.
Trying to create DVD from m2v and wav files
By JSLayton in forum Authoring (DVD)Replies: 8Last Post: 28th Jun 2011, 18:56 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
DVD Studio Pro will not import m2v files!
By CLE in forum MacReplies: 5Last Post: 20th Jan 2008, 18:14 -
Demux DVD Video to separate M2V and AC3 files
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 3Last Post: 6th Oct 2007, 21:03 -
Joining M2V & AC3 files for DVD burning, Subtitle creation sub position
By blue2 in forum Authoring (DVD)Replies: 15Last Post: 29th May 2007, 09:56
