  1. I was looking at the CD writers page on here and wanted to check m ine against the list. However all mine says is
    HL-DT-ST RW/DVD GCC-4120B
    Device type: DVD/CD ROM DRIVES
    Manufacturer: (Standard CD-ROM drives)
    How can I tell which mine is, as this doesnt give me any real info at all?
    This is so I can look into the buffer under run problem that I might have.
    Oct 2002
    Kentucky, USA
    I did a little research and there IS a manufacturer called HL-DT-ST and will pop up with several hits in most search engines. but he is right, it is part of LG/Goldstar.
    It's not about getting what you want, it's wanting what you've got
  3. heh...LG (lucky goldstar) i believe is one of those cheap korean brands
