hi, i tried following the guide in producing mpeg still video (posted in vcdeasy.org). Unfortunately, i am not successful in producing a vcd photo album. My pictures are in jpeg format, and i use Nero 5.5x to burn the .cue to my CDRW using plextor.
Nero has a way of putting your jpegs into vcd format but i find very restricting. VCDeasy has the bells and whistles but i could not make it run. Pls help.
Thank you in advance!
k45Guest
Hello,
What exactly is the issue?
What is the thing that does not work out?
Authoring, display?
However, maybe try the philips vcd 2.0 toolkit to generate stills .. this is what i have to do since mjpeg generated vcd stills seems not 100% compliant and don't display with my player,,.,..:.:: jesus2099 / shamo + top-moumoute films limited ::.:..,.,, -
hi,
sorry for not responding, but i was actually trying to solve my problem by reading thru all the write up in vcdeasy site!
the issue is, i see a blank display everytime i load the newly burnt vcd to my pioneer dvd/vcd player. Ops, I guess i already gave the solution! I downloaded the Mjpeg Tools (v1.6.0 rc2), patched my vcdeasy and everything fell into places.
for those who are beginners like me, you can download it in www.vcdeasy.org, click beta version (on the left pane) and click Mjpeg Tools (v1.6.0 rc2, 564 KB).
thanks for your time jesus2099. I might try your suggestion too!
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 04:48 -
VCDEasy doesn't work in Vista...
By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)Replies: 14Last Post: 26th Dec 2010, 20:20 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
