I apologize up front for my severe case of newbie-ness. I've only used Nero to make VCDs in the past but I have a few files that need some tweaking, namely cropping out some signal noise(or something) along the top and have a few questions-will cropping it out result in a stretched picture? If so can it be masked out instead? And of course, what would be the most newbie friendly program TMPGEnc, vDub, or something else? Thank you for any advice you might offer.
[img]http://photo.starblvd.net/~account71469/2-1-2.jpg?i=1034408974&pw=*36773D96EA17[/img]
Results 1 to 9 of 9
TMPGenc under settings/advanced/clip frame.
Select Mask top and then adjust to taste, I recommend units of 8 pixels. -
You can only crop if you re-encode, presuming you want to correct already created mpegs. The best answer is to use TMPG to encode to VCD from your original source, and use the clip frame function. To re-encode VCD mpeg will result in loss of quality.
Originally Posted by paul714
Using TMPGEnc as above, means you have to re-encode the video, and if you have already captured to mpeg 1, you might not want to do that
That is why people sometimes capture to AVI, they are a lot easier to work with later, Vdub can use a cropping (Filter) and remove bad frames, before the final conversion to mpeg 1 with TMPGEnc.
The problem is, if your capture is mpeg 1/2, you may have a few frames dropped without knowing it, start to edit these and you may get lip sync problems. -
Thanks for your input guys, it is appreciated. I'll use TMPG to mask it rather that crop it as I had planned. KingJohn- I'll definately keep that in mind when I finally get a capture card, unfortunately I got these on CDR from a trade. Looks like it 's time to finally get over being intimidated by TMPG
So I crop it and then use the mask to make up the difference, masking it won't just overlay the line in the video hiding it...I think I'm catching on(hopefully) Thanks again Banjazzer!
The cropping will get rid of the lines. I don't think masking will make much difference. It certainly doesn't appear to affect the aspect ratio. Although, you can have different coloured masks, if you want. 8)
what cuesheet prog do u use
By mikeo1313 in forum AudioReplies: 2Last Post: 18th May 2010, 23:03 -
which prog to capture ?
By hydra3333 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 03:19 -
Easiest and fastest ripping prog?
By Valioser in forum DVD RippingReplies: 1Last Post: 5th Mar 2009, 17:57 -
how can i Write And Encode 2-pass on same prog
By bassam319 in forum Video ConversionReplies: 4Last Post: 27th May 2008, 22:00 -
Which prog to get audio to work on DVD?
By bytheway in forum Newbie / General discussionsReplies: 2Last Post: 3rd Apr 2008, 19:40
